Please HELP - Logon Password required after installing cri..
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.security_admin (More info?)
I am using XP professional and cannot logon anymore since automatic update
has installed some critical updates. After booting successfully the system is
asking me for a password, although I have never specified one!How can this
happen?
I am the only user and have tried several passwords including username.
leaving blank ect. but have no idea what it could be. After a few attempts it
comes up with the following error message:
The system cannot log you on due to the following error: The program issued
a command but the command lenght is incorrect. Please try again or consult
your system administrator.
Can anybody help me please?
Thanks
Reino
Hi james,
have solved the problem, nothing helped then I had an idea and tried it the
easy way:
press F8 during rebooting your machine until it comes up with some options
(Safe Mode ect. ect.) and choose the following:
start windows with the last known good configuration
it will start up normally now, without asking you for a password because it
remembers the windows configuration from before you have installed your
critical updates which have caused this problem.......so its excluding them
automatically.
Just make sure, that you dont install them again and deactivate the
automatic update or follow instructions for automatic logon.
Reinho9ld
> happen?
> Thanks
> Reino
Sorry :)
Just read the second post :)
For direct e-mailing remove "-spam" from my e-mail address
Best Regards,
Matija Hrovat
"Reino" <Reino@discussions.microsoft.com> wrote in message
news:E93F5851-8841-4483-859B-1244CA40E648@microsoft.com...
> is
> happen?
> it
> issued
> Thanks
> Reino
no problem, thanks anyway 🙂!!!
"Matija Hrovat" wrote:
> Sorry :)
> Best Regards,
> Matija Hrovat
> > is
> > happen?
> > it
> > issued
> > Thanks
> > Reino
I have the same problem.
I think the problem is installing security update KB885835 from
Microsoft.
This is the last update that I installed before this error message.
Solution: Do not trust to the automatic update just turn it off.
:aaa
Glarus
Posted via http://www.mcse.ms
View this thread: http://www.mcse.ms/message1295892.html
