davidarad02 :
yes, thats the only way that G-Sync is possible (i think that IPS and G-Sync aren't compatible and thats why theres no IPS G-Sync monitor).
Dude, seriously? You need to read up on things before you start telling people information. All you had to do was watch the video or click the link I put, which was from the Asus website.
Do note that [the new 4K ROG G-Sync monitor will not be] a replacement for the current model and both PGs will exist side-by-side as top-tier gaming monitors, providing a choice to gamers looking at 27-inch displays; between the fast gaming 144Hz, WQHD/8-bit TN PG278Q and the higher 4K resolution, with in-plane switching (IPS spec) LCD in the PG28AQ .
You can also just
Google it. Every major tech new source has covered the Asus PG28AQ, and they all list the IPS spec with Gsync.
I usually think it's in bad taste to call people out like this, but you also said the Dell he was looking at was 30 hz despite the fact that Dell's official specs clearly list it as 60 hz - a deal breaking issue. When people are trying to rely on your advice, accuracy matters.
Ali977 :
i read them aha, but i wanted an example, ill just google haha
The best place to look for technical information about displays is a website called
TFT Central
It's a bit heavy because they don't simplify anything, but once you get used to the lingo, you'll be fine.
