Please help me choose a PSU for this build
Loukic
I did a lot of research and it feels like the more research I do the more I get confused
This is my build
Intel G4560
Zotac GTX 1060 3gb amp edition
Wd blue 1tb
Corsair vengeance 8gb ddr4 2400hz
Gigabyte h110m Mobo updated bios
I live in India so the prices of even lowly psus are a bit high. My Max budget is 5000rs approx 70$.
I want to go for CX 430 but I have heard Its not the best quality. So I would like to know what you guys think
For your build, i suggest getting a good quality (Tier two) Seasonic S12II-520,
amazon: http://www.amazon.in/Seasonic-S12II-520-Watt-Power-Supply/dp/B005O8PNSM
While the PSU is a bit over your budget, it's also a very good PSU for your build. PSU comes with 80+ Bronze certification and 5 years of OEM warranty.
My AMD build (full specs in my sig) is also powered by S12II-520. PSU is 3 years old and still going strong. Only downside is that it's fully wired and gives a nice headache in cable management. But when to compare it with Corsair CX series, it's far better since Corsair CX series PSUs are low quality (Tier four) units.
PSU Tier list: http://www.tomshardware.co.uk/forum/id-2547993/psu-tier-list.html
For cheaper PSU, you can go...
For cheaper PSU, you can go with Antec VP550P PSU which is mediocre quality (Tier three) PSU,
amazon: http://www.amazon.in/Antec-VP550P-550-Watts-PSU/dp/B00565RGQA
While better build quality than Corsair unit, it's build quality still isn't as good as Seasonic units have.
