Please help me figure out if I need to buy a different case or cpu cooler to make everything fit
supyk
5
Specs:
Ryzen 7 1800X 3.6GHz
MSI - B350 TOMAHAWK ATX AM4
G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3200
Samsung - 960 PRO 512GB M.2-2280 Solid State Drive
SeaSonic - FOCUS Plus Gold 650W 80+ Gold
1070 TI GTX (planned video card currently gonna run my old 960)
Originally I wanted these:
Noctua - NH-D15 SE-AM4
Fractal Design - Meshify C ATX Mid Tower Case
Case has max cpu cooler allowance of 172 mm
Noctua is 165 MM
https://noctua.at/media/wysiwyg/faqs/nh_d15_clearance_2016.png
Ram is 42MM tall. I'm assuming i need to raise the front fan from noctua by 8mm which makes the cooler 173mm making it 1mm too tall for the case.
I have no idea how exact these measurements are in a real world setting with the motherboard. Should i be safe and just go with a different cooler or case?
Appears you are good to go, PCPartPicker is good at spotting fit issues. Hope this is for video editing or some other thread demanding application and not gaming.
PCPartPicker part list: https://pcpartpicker.com/list/TgrZ4C
Price breakdown by merchant: https://pcpartpicker.com/list/TgrZ4C/by_merchant/
CPU: AMD - Ryzen 7 1800X 3.6GHz 8-Core Processor ($377.60 @ Newegg Marketplace)
CPU Cooler: Noctua - NH-D15 SE-AM4 140.2 CFM CPU Cooler ($89.90 @ Amazon)
Motherboard: MSI - B350 TOMAHAWK ATX AM4 Motherboard ($95.99 @ SuperBiiz)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3200 Memory ($201.99 @ Newegg)
Storage: Samsung - 960 PRO 512GB M.2-2280 Solid State Drive ($299.00 @ Amazon)
Video Card: MSI - GeForce GTX 1070 Ti...
Video Card: MSI - GeForce GTX 1070 Ti 8GB DUKE Video Card ($999.99 @ Newegg Marketplace)
Case: Fractal Design - Meshify C ATX Mid Tower Case ($86.99 @ SuperBiiz)
Power Supply: SeaSonic - FOCUS Plus Gold 650W 80+ Gold Certified Fully-Modular ATX Power Supply ($83.99 @ SuperBiiz)
Total: $2235.45
Generated by PCPartPicker 2018-01-18 11:33 EST-0500
supyk
5
Thanks for the response. Yes primary function will be for be for editing videos using Redcine-X Pro 64 bit (for 4k) and Adobe Suite for everything else. Secondary will be for gaming/streaming.
There is another case i found that has a 180mm clearance (Rosewill Cullinan ATX case) which I can fall back to if needed. I do like the rosewill, but rather get the Fractal.
I had no idea that PCPartPicker was actually that credible in spotting fit issues/compatibility issues. Good to know.
