G
Guest
Guest
Archived from groups: alt.comp.periphs.dcameras,rec.photo.digital (More info?)
I've narrowed my selection down to the Sony DSC-W1 and Canon S500.
I've read the reviews of both cameras at various sites (not user
reviews, but indepth expert/editor reviews), but none seem to make a
strong recommendation over the other between these two.
Here are some of the reviews I've read so far:
http://www.dcresource.com/reviews/canon/powershot_s410_s500-review/index.shtml
http://www.dcresource.com/reviews/sony/dsc_w1-review/index.shtml
http://www.steves-digicams.com/2004_reviews/w1.html
http://www.steves-digicams.com/2004_reviews/s500.html
http://www.imaging-resource.com/PRODS/S500/S50A.HTM
http://www.imaging-resource.com/PRODS/W1/W1A.HTM and the side-by-side
comparisons can be found here,
http://www.dpreview.com/reviews/compare_post.asp?method=sidebyside&cameras=canon_s500%2Csony_dscw1&show=all
Because of Carl Zeiss lens used by DSC-W1, it seems to better pictures
with less noise and aberration. Also, the W1 has some manual
aperature options, while the S500 has none. However, the S500's white
balance options are supposed to be better than the W1.
Based upon the reviews, which camera would you guys choose? Thanks
for your time and courtesy!
