Please Help Me!!
outlawstar223
Well Ladies and gentleman, I had been upgrading my old computer just to add some new parts. Its an 800mhz computer based on the tyan s1854 trinity 400 Mobo. I had 384 MB of Ram running on that. well the other day i got got a new PSU and new RAM. My computer was running fine before that. So I went to install it and i got this loud beep and i was like what the [-peep-]. So then i uplugged it and removed the RAM that I had put in and replaced it with the original. And then it just wouldnt start. Then I really got scared. Then I went and replaced the PSU with my old one and when i was doing that i noticed that my VID card had ben jostled out of place. THen i turned it on again and nothing happened so i turned it off again tried to make sure everything was plugged into tightly and it didnt want to turn on. So PLease someone help me. It hasnt turned on since then.
Replace all your original components back in, make sure everything is seated correctly, and try again. Make sure the Power On wire is plugged into the complex header thingy.
Also, what compondents did you buy exactly? What make / speed of RAM etc.
_______________________
<A HREF="http://www.moviewavs.com/MP3S/TV_Shows/Simpsons/flanderssong.mp3" target="_new">Audio Sig</A>
