Please Help! My Computer wont hook up to the monitor
Yopiedoo
Commendable
Mar 22, 2016
18
I just recently built a computer. When I go to hook it up to the monitor, nothing pops up... It says no signal. I have an asrock motherboard, with no onboard video ports. The power supply is fine, and everything is powering up. The only thing that isnt working is the connection to the monitor! I have tried HDMI and VGA but nothing works. Please help D:
thats ok
yeah but if you accidentally bent any pins putting it in you would get the symptoms you are getting
it would all come on but no display
could try re-seating the graphics card--if it has the little clip at the end that should click into place if its in right
