Please help
Eriond
25
Shuttle AN35 (nf 400 ultra)
ATI Radeon 9500
1 gig Corsair XMS 333 ram
2500 barton
i boot the computer with just the above in
with 300 watt Enlight (came with case 7237)
computer boots/posts/works with all equipment
with 300 watt Antec (came with the lanboy case)
external power header attached to vid card
power blinks on, heat sink spins up power drops after 1/2 second and the computer will not even attempt to restart until the power is disconnected and plugged back in (same thing repeats)
external power header not attached to the vid card
system boots, but hi/low beeping (vid card not attached) repeats and no official boot, system will let me shut down and restart, same results
with 300 watt Allied PS (rma exchange at Newegg)
with 400 watt Manhattan PS (mom/pop shop)
Is Enlight a super PS or is something fishy going on here?
I think you can safely rule out the P/S as being the problem. When you mounted the M/B did you make absolutely sure you only had mounting studs at the mounting holes on the M/B, and if the backplate came with the studs premounted you removed the unnecessary ones? It sounds to me like a shorted out M/B.
<b><font color=purple>Details, Details, Its all in the Details, If you need help, Don't leave out the Details.</font color=purple></b>
Well, I had to take the motherboard out everytime I replaced the power supply b/c of a tight fit. I don't think I repeatedly grounded the mobo with every ps other than the first?
If you're positive the M/Bs not shorted, then either you have a bad M/B, CPU, or RAM, P/S wise the second change out eliminated that as a possibility.
Did you use the same case every time, even with the first power supply?
There's a possibility you have always had an intermittant ground, because there was just a hairs width at one time separating the offending mount durring one attempt, so that one attempt worked.
Also, you have to have the power button attached, and use it, to get the thing to power up. Just plugging it in only spins the fans for a couple seconds without turning the system on.
<font color=blue>Only a place as big as the internet could be home to a hero as big as Crashman!</font color=blue>
<font color=red>Only a place as big as the internet could be home to an ego as large as Crashman's!</font color=red>
could it be that you arn't giving your system enough juice?
Normally 350watts is the recomended minimum...probably the mom and pop psu was way overrated...
I beleive enlight uses fortron powersupplies? if this is the case that powersupply was putting out way over 300 watts (more like 350-380)
Proud owner of DOS 3.3 :smile:
Yes, I used the same case every time.
this is the exact order (the power/reset are attached to the mobo)
Enlight = work
Antec = no work
Allied = no work
Manhatten = no work
Enlight (again, same PS) = work
I currently have the computer running with the enlight (everything is hooked up and windows is running). I would simply like to know why Enlight PS is the only one that works?
Thanks
It may be a compatible problem.So u know it is hard to say what the problem really is.Then i guess the electric current`s supply is the key,that is to say some PS can give enough for the mobo,but some not.
if the powersupply is giving shitty current (mixed with some AC) then the computer may be unstable
if the voltage is fluctuating...then the computer may be unstable...
it has nothing to do with compatability...
Could it be how much power is put out on each rail of the power supply? (3V, 5V, 12V)
<A HREF="http://forumz.tomshardware.com/hardware/modules.php?name=Forums&file=viewtopic&p=361277#361277" target="_new"> Why ur video won't run </A>
The loving are the daring!
well 300 watts is not enough for most systems....it is normally recomended to use 350 at a bare minimum....
so you are stretching all powersupplies very far...
Oh I agree about the 350 Watts minimum. I'm just thinking why one will work an the others won't.
The anandtech article on PSU's describes how the various PSU's put out different amounts of power on the different rails.
I'm requiring an excess amount of watts from my Enermax and it's the only one able to sustain that? But my test was with only the cpu/motherboard/vid card? That surely cannot be 300 watts can it?
<A HREF="http://www4.tomshardware.com/howto/20021021/powersupplies-02.html" target="_new">Toms </A>
IDE Hard Drive (RAID group) 0.80 A 2.00 A 4 112.00
Processor AMD Athlon XP 2100+, 1.75 V 7.49 A 1 89.88
RAM Module (128 MByte DDR-DIMM) 2.00 A 3 30.00
AGP Graphics Card (Nvidia GeForce 4 Ti 4600) 6.00 A 2.00 A 1 29.80
Motherboard with on-board devices 3.00 A 2.00 A 0.30 A 1 23.50
DVD-ROM 1.20 A 1.10 A 1 19.20
CD-RW 1.20 A 0.80 A 1 15.60
IEEE 1394 1.60 A 1 8.00
USB Devices 0.50 A 2 5.00
PCI Sound 0.50 A 0.50 A 1 4.15
Floppy 0.80 A 1 4.00
PCI-LAN 0.40 A 0.4 0A 1 3.32
System Fan 0.25 A 1 3.00
Processor Fan 0.25 A 1 3.00
PCI Modem 0.50 A 1 2.50
Keyboard 0.25 A 1 1.25
Mouse 0.25 A 1 1.25
Total Power Required 355.45 W
You had what plugged in for your test?
All I wanted was for the things to turn on. The only things I had plugged in were the 9500 Radeon Video card, Shuttle AN35 Ultra 400 mobo, Barton 2500+ with fan
All the power supplies would turn on if I didn't have the external header on the video card plugged in, but they all gave the message your video card needs the power connected.
Only the enlight would start with the video card plugged in. The others would provide a second or so worth of power and then turn off, the only way to get them to try to start again was by unplugging the power.
if one 128MB Dim used 30Watts then 1GB uses?
I thought it was about 8Watts for 128 of SDRAM.
Is it 30W for 128 DDR? Seems a bit much.
Yep it is <A HREF="http://www.overclockers.com/articles696/" target="_new"> memory power </A>
Hmmmm, can anyone explain why Toms used 30W for 128MB of DDR?
Eriond, the point I'm trying to make here is that the power supplies put out different amounts of power on their respective power rails. If you've got the wrong proportion the power supply total Watts are not going to help.
The loving are the daring!<P ID="edit"><FONT SIZE=-1><EM>Edited by Flinx on 08/31/03 07:07 PM.</EM></FONT></P>
dont beleive everything you read...if all psus put out what they stated enermax and antec would not be in buisness cause they charge too much...
Fact of the matter is that 90% of powersupplies are over rated....and the fact that your 400 watt psu was a no name brand makes me very suspicious of its quality...
