[SOLVED] Please help!
Jul 23, 2020
37
I have and Asus Prime H310M-E R2.0, which has 2 fan headers, cpu, and cha. The problem is i want to buy 6 "InWin Sirius Loop" fans (these fans can be connected consecutively) but i dont know if some voltage problem would happen.
If you're using the triple fan packs times two, you can daisy chain three fans in the same pack and have that triple fan daisy chain come off of one fan header. So in this case, you're inevitably going to need a fan hub like the one made by Swiftech, Phanteks or Silverstone. Where are you located?
