G
Guest
Guest
Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
im not sure if this is exacly a motherboard problem but when i start up the comp sometimes is says that hardare monitor found a problem, when i check it is says that the 5v+ circuit is only at about 4.5v. all yesterday my comp wouldnt work properly. it would freeze up at the windows loading screen or at best at the logon screen.
ben.riesinger@booomail.com
