[SOLVED] Please review my Custom PC build
dlloyd1025
15
Just wanted to ask the community their opinions if my build is worth the money, or if I would have been better off going with a pre-built system. Total price in the end including taxes is just over $1200, as I did not buy a GPU since I moved my GTX 1050 TI from my old pc since it was only about a year or so old.
Components:
Intel Core i7-11700K Desktop Processor 8 Cores up to 5.0 GHz Unlocked LGA1200 (Intel 500 Series & Select 400 Series Chipset) 125W - $389.99
ASUS Prime Z590-P LGA 1200 (Intel 11th/10th Gen) ATX Motherboard (PCIe 4.0, 10+1 Power Stages, 3X M.2, 2.5Gb LAN, Front Panel USB 3.2 Gen 2 USB Type-C, Thunderbolt 4 Support) - $165.00
Corsair 4000D Airflow Tempered Glass Mid-Tower ATX PC Case - Black - $117.05
SAMSUNG (MZ-V8V1T0B/AM) 980 SSD 1TB - M.2 NVMe Interface Internal Solid State Drive with V-NAND Technology - $116.59
Corsair Vengeance LPX 32GB (2X16GB) DDR4 3200 (PC4-25600) C16 1.35V Desktop Memory - Black - $134.99
140mm Case Fan 2-Pack Computer Case Fan with Advanced Fluid Dynamic Bearing for Ultra Quietness and Silent Operation Standard 140 mm Case Fan 2 Pack with 3 Pin & Molex / LP4 Connectors -$15.99
Thermaltake TH360 ARGB Motherboard Sync Edition AMD/Intel LGA1200 Ready All-in-One Liquid Cooling System 360mm High Efficiency Radiator CPU Cooler CL-W300-PL12SW-A Black - $149.99
Thermaltake Smart Pro RGB 650W 80+ Bronze Certified PSU. Ultra Quiet Smart Zero 256-Color RGB, Fan Fully Modular, ATX 12V 2.4/EPS 12V 2.92 Power Supply. 7 Year Warranty PS-SPR-0650FPCBUS-R - $ 79.95
I debated for several weeks when researching my parts, if it would be worth it to get a system that comes with a newer GPU. But I ended up going this route since I don't trust some Pre-Built PC companies and figured I could do it better. I am quite happy with my results, and everything runs amazing.
Please everyone let me know what you think, I would love to hear all opinions.
Good CPU, decent board, good case, decent SSD, decent RAM, you almost made it until the PSU(Tier D). For this card it wont hurt probably but a more powerful card may suffer. I would get a better PSU if its still within return window...
https://www.tomshardware.com/reviews/thermaltake-smart-pro-rgb-850w-psu,5071.html
