Hi all,
Approximate Purchase Date: In the end of October
Budget Range: Around/Below 100K to 130K Indian Rupees.
System Usage from Most to Least Important: Animation(Lighting and Rendering), GPU rendering, Gaming, Browsing, Sometimes overnight rendering( yes only sometime).
Software usage: I will be using Software like Maya (Most), Unreal engine, Substance Painter, Adobe Photoshop & Aftereffects, Foundry Nuke & Katana and Renderers like Arnold, Vray, Renderman, Redshift etc.
Are you buying a monitor: Yes
Parts to Upgrade: Building from Scratch
Do you need to buy OS: No, I have.
Please note that if you're using an OEM license of Windows, you will need a new one when buying a new motherboard.
Preferred Website(s) for Parts: I am buying from Local brick and mortar shops , but yes was checked the pricing and comparison on these sites. https://www.amazon.in , https://in.pcpartpicker.com , https://www.primeabgb.com , https://mdcomputers.in
Parts Preferences: Not really, but i am opting for Intel over AMD for long term goal.
Overclocking: Maybe, But not for CPU
SLI or Crossfire: Don't know much
Your Monitor Resolution: 1920x1080, atleast 100% sRGB,HDMI, DVI ports, 24inches.
Additional Comments: This is my final configuration unless you guys recommend something else . will upgrade the following maybe after 6-8 months
And Most Importantly, Why Are You Upgrading: Building from scratch my second PC. First is History
List of Parts i have selected :
CPU - Intel Core i7 9700K 3.6 Ghz
https://mdcomputers.in/intel-core-i7-9700k-bx80684i79700k.html
Motherboard - MSI Z390-A PRO or any other suggestions.
https://mdcomputers.in/msi-z390-a-pro.html
GPU - Galax GeForce RTX 2070 Super EX (1-Click OC) 8GB GDDR6
https://www.primeabgb.com/online-pr...uper-ex-1-click-oc-graphic-card-27isl6mdu9ex/
PSU - CORSAIR VS650 SMPS - 650 Watt or any other if you suggest
https://mdcomputers.in/corsair-vs650-cp-9020172-uk.html
RAM - Corsair (8 x2 )16 GB Vengeance LPX DDR4 3600 Mhz
https://mdcomputers.in/corsair-vengeance-lpx-16gb-ddr4-3600mhz-cmk16gx4m2b3600c18.html
CPU Cooler - COOLER MASTER MASTERLIQUID ML240L RGB or any other suggestion
https://mdcomputers.in/cooler-master-masterliquid-ml240l-rgb-mlw-d24m-a20pc-r1.html
Primary storage - 250-512 GB M.2 / SSD, Please suggest any other. ( brand and price also)
* Intel 512GB 660P NVMe M.2
https://www.primeabgb.com/online-pr...b-660p-nvme-m-2-internal-ssd-ssdpeknw512g8x1/
* Adata Ultimate SU650 240GB M.2
https://mdcomputers.in/adata-ultimate-su650-240gb-m-2-asu650ns38-240gt-c.html
Secondary storage - WD or Seagate 1TB HDD
https://mdcomputers.in/seagate-1tb-barracuda-st1000dm010.html
Case - Antec Dark Avenger DA601 RGB (E-ATX) Mid Tower or any other suggestion
https://www.primeabgb.com/online-pr...e-atx-mid-tower-cabinet-tempered-glass-panel/
Monitor - These are the few i have selected; You can suggest good and budget monitor.
* Dell U2415
https://www.primeabgb.com/online-pr...4-1-6ms-gtg-dual-hdmi-widescreen-lcd-monitor/
* Dell S2418H
https://www.primeabgb.com/online-pr...s2418h-24-led-lcd-black-freesync-ips-monitor/
* LG 24MP59G
https://mdcomputers.in/lg-24-inch-rgb-amd-freesync-gaming-24mp59g.html
* Benq GW2480
https://mdcomputers.in/benq-23-8-inch-monitor-gw2480.html
Thanks for Your comments, Eagerly waiting for your reply.
- RAM - may be upgrade to 32 GB
- Secondary storage - will add another TB
* Dell U2415
* Dell S2418H
* LG 24MP59G
* Benq GW2480
