Pls give suggestions for a sub 300 $ display
lHEadShoT
13
I need some suggestions for a 1080 ips panel 144 mhz ...give more than one as it might not be available in my country
N.p i am using gigabyte g1 gtx 980 ti card
Thanks in advance
D
If you really want IPS for the colors and viewing angles, go for the dell. If you just want a quality gaming monitor, go with the asus. It also has bezelless displays, which make it look INCREDIBLE!!!
I don't know why you would need 144mhz, but I think gsync would be great for your needs(but they are REALLY EXPENSIVE!
Gsync: http://pcpartpicker.com/part/acer-monitor-umfb0aaa01, http://pcpartpicker.com/part/aoc-monitor-g2460pg, http://pcpartpicker.com/part/acer-monitor-umhb0aaa01
IPS 60HZ: http://pcpartpicker.com/part/lg-monitor-22mc57hqp, http://pcpartpicker.com/part/acer-monitor-umvh6aa003, http://pcpartpicker.com/part/lg-monitor-27mp33hq
144HZ(NO IPS): http://pcpartpicker.com/part/acer-monitor-umfg6aab01, http://pcpartpicker.com/part/asus-monitor-vg248qe, http://pcpartpicker.com/part/aoc-monitor-g2460pqu
**I coud not find any ips gsync monitors within your price range. I also could not find any ips 144hz monitors within your price range. All of the monitors above have a 5ms response time or less.
thanks for your reply ,, unfortunately i couldn't find any of those available so a looked up and found a couple of choices but it is a little bit confusing since i can't compare them based on the spec sheet ,,, so which of these would you recommend
1 ASUS VG248QE http://www.amazon.com/dp/B00B2HH7G0/ref=psdc_1292115011_t2_B00IKDFL4O
2 ASUS MX279H
http://www.amazon.com/dp/B00B17C5KO/ref=psdc_1292115011_t3_B009C3M7H0
3. RL2455HM
http://www.amazon.com/BenQ-Gaming-Monitor-RL2455HM-24-Inch/dp/B007HSKSMI/ref=sr_1_3?ie=UTF8&qid=1442066191&sr=8-3&keywords=benq+gl2450
4. Dell UltraSharp U2412M
http://www.amazon.com/Dell-UltraSharp-24-Inch-LED-Lit-Monitor/dp/B005JN9310/ref=pd_cp_147_4?ie=UTF8&refRID=1KW8PJ5R1H35N72XXK0E
my primamry use would be for gaming and i 'll do some photo editing on it
kinda of stupid question ,,, is the asus VG248QE is the only one of those 4 which have Nvidia 3d vision ready and Nvidia 3D lightboost ?
