Hi folks,
a first time PC builder needs some help. 😊 Will highly appreciate your comments on the following:
- As the price for the same GPU increases in the "Reference unit -> Founders Edition -> Add-in board/AIB" paradigm, which version has the best "bang for buck" after which it makes sense to buy the next-gen Reference GPU rather than keep on moving up within the said paradigm?
- Which version of GPU (Reference/Founders/AIB) provides better cooling (= more stable and silent functioning)? Are AIB GPUs considerably more silent compared to the Founders Edition?
- Is it true that the same GPU card may have several variations, e.g. single-slot/dual-slot, full-height/half-height? Is it true that larger versions will always cool better and run quieter than smaller ones?
- VRAM size. The more - the higher can be the resolution and detalization of the game, right? How much VRAM do I need to play 85% of modern games in: 1080p (1920x1080, FHD); 2K 1440p (2560x1440, QHD); 4K 2160p (3840x2160, UHD)?
