I bought an old HP PC (HP EliteDesk 800 G1 SFF) and want to change to a more powerful PSU for a dedicated video card (this PC uses a 240W PSU).
The problem here is, the motherboard doesn't use a 24pin power connector like other ATX motherboards, instead it uses (1) a 6-pin auxilary (2) a 2x2 connector, which I believe to be the same as the CPU connector and (3) a 3x2 connector as in the picture above. For the 6-pin auxilary, which is quite outdated, I can buy an adapter to convert 24-pin into 6-pin auxilary, the 2x2 connector is available on today PSUs, the only problem is the 3x2 connector
I was thinking if I can use the 3x2 connector on the PSU for this (which is for the video card), so I compared it to the 3x2 connector on the video card and realised they are nearly the same, the only difference is that the 5th pin on the video card is a tapered one, while the 5th pin on the mother board is square.
(photo borrow from a guy on the internet, the 5h pin is the bottom middle pin)
So what I wonder is
- Will a tapered pin fit a square slot ?
- If it fits, is there any problem if I use the video card power connector for the motherboard?
- And BTW what is that 3x2 connector for ? This PC doesn't have a dedicated video card (although it has 2 PCI-e slots), and I think the motherboard is powered by the 6-pin auxilary already ?
