popups when im not useing explorer
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.basics (More info?)
they just popup when im not on the net, how do i stop this from
happing??????????
Download a spyware remover such as SpyBot or Ad-Aware. This should
eliminate the problem.
Thanks,
Clinton Fitch
Partner
C3 Technology
http://www.c3-technology.com
"nicebadboy" <none@thistime.com> wrote in message
news:nmkmi017ov93ko6ggvi5l404s625jclgi2@4ax.com...
> happing??????????
>-----Original Message-----
this from
>happing??????????
>You have spyware on your computer. Download Spybot or
Adaware for free and scan for spybots. Then delete the
buggers. If that does not work, download Hijack This for
free and follow the directions. Be careful not to delete
importants stuff with Hijack This.
Greetings --
There are at least three varieties of pop-ups, and the solutions
vary accordingly. Which specific type(s) is troubling you?
1) Does the title bar of these pop-ups read "Messenger Service?"
This type of spam has become quite common over the couple of
years, and unintentionally serves as a valid security "alert." It
demonstrates that you haven't been taking sufficient precautions while
connected to the Internet. Your data probably hasn't been compromised
by these specific advertisements, but if you're open to this exploit,
you may well be open to other threats, such as the Blaster Worm that
swept across the Internet last year and the currently active Sasser
Worm. Install and use a decent, properly configured firewall.
(Merely disabling the messenger service, as some people recommend,
only hides the symptom, and does little or nothing to truly secure
your machine.) And ignoring or just "putting up with" the security
gap represented by these messages is particularly foolish.
Messenger Service of Windows
http://support.microsoft.com/default.aspx?scid=KB;en-us;168893
Messenger Service Window That Contains an Internet Advertisement
Appears
http://support.microsoft.com/?id=330904
Stopping Advertisements with Messenger Service Titles
http://www.microsoft.com/windowsxp/pro/using/howto/communicate/stopspam.asp
Blocking Ads, Parasites, and Hijackers with a Hosts File
http://www.mvps.org/winhelp2002/hosts.htm
Oh, and be especially wary of people who advise you to do nothing
more than disable the messenger service. Disabling the messenger
service, by itself, is a "head in the sand" approach to computer
security. The real problem is _not_ the messenger service pop-ups;
they're actually providing a useful, if annoying, service by acting as
a security alert. The true problem is the unsecured computer, and
you've been advised to merely turn off the warnings. How is this
helpful?
2) For regular Internet pop-ups, you might try the free 12Ghosts
Popup-killer from http://12ghosts.com/ghosts/popup.htm, Pop-Up Stopper
from http://www.panicware.com/, or the Google Toolbar from
http://toolbar.google.com/, which is what I use.
3) To deal with pop-ups caused by any sort of "adware" and/or
"spyware,"such as Gator, Comet Cursors, Xupiter, Bonzai Buddy, or
KaZaA, and their remnants, that you've deliberately (but without
understanding the consequences) installed, two products that are
quite effective (at finding and removing this type of scumware) are
Ad-Aware from www.lavasoft.de and SpyBot Search & Destroy from
www.safer-networking.org/. Both have free versions. It's even
possible to use SpyBot Search & Destroy to "immunize" your system
against most future intrusions. I use both and generally perform
manual scans every week or so to clean out cookies, etc.
Additionally, manual removal instructions for the most common
varieties of scumware are available here:
PC Hell Spyware and Adware Removal Help
http://www.pchell.com/support/spyware.shtml
More information and assistance is available at these sites:
The Parasite Fight
http://www.aumha.org/a/parasite.htm
Bruce Chambers
Help us help you:
http://dts-l.org/goodpost.htm
http://www.catb.org/~esr/faqs/smart-questions.html
You can have peace. Or you can have freedom. Don't ever count on
having both at once. - RAH
> happing??????????
