Question Port forwarding Issue
ShourobB
12
I have a rogers modem going into Netgear nighthawk xr450 but the pc running the server is plugged into the modem, the port forward in done but it still shows as closed. the port is 25565 which I put in for the external and internal port(yes it's a Minecraft server, don't judge). I've tried running the server and getting someone to connect but they cannot connect. please help
Lets start with some terminology:
  • "modem" is a device with (eg coax or DSL) connection to ISP, and Ethernet port providing single (public) IP address;
  • "router" is a device with WAN port and LAN/WiFi ports, tasked with "dividing" the WAN port among LAN/WiFi users.
So, if you have plugged your PC directly into the modem, you don't need any port forwarding, as your PC is directly connected to the Internet.
Can you port a picture of how your devices are connected?
So Rogers gave us a router which is crap so we use a different one and disabled the wireless function on it effectively making it a modem
We ran Ethernet to a switch from there it runs to thr router, it also runs to the pc I'm hosting the server from. As result I still need to port forward in the "modem" setting
It also run through walls so I can't get a picture of it
