Possible faulty GTX 1070 card? Help is appreciated
RamosL22
26
Hey everyone,
Recently I made the jump to the windows 10 upgrade from windows 7, horrible decision! Anyways this was on Thursday. So at the time I was running a gtx 970 and it worked great on windows 7 and as soon I upgraded to windows 10, I started noticing stuttering and framerate drops.
On Total War Warhammer, it became very laggy at times. The benchmark test in the video settings area gave me an average of 55 FPS, yet it still lagged on the campaign map, when on windows 7 it was very stable. So I tried everything I could google and nothing seemed to fix it, and it seems like everyone who upgraded to 10 were having gaming issues.
Well, to add to my problem, I also ordered a Zotac GTX 1070 AMP Exetreme edition pictured here:
http://imgur.com/a/w4DHL
http://imgur.com/a/QmAbv
Other system specs are:
I5-4690K (With coolermaster hyper d92 heatsink)
8 gigs DDR3 Ram
MSI Z97 Gaming 5 Mobo
Brand new PSU Corsair CX750M (upgraded from CS650M today!)
500 GB SSD and 500 GB HDD
When I installed the GTX 1070, I was surprised it needed not one, but two sets of 6 pin connectors. I didn't have a 2nd set of dual pcie 6+2 for the splitter, so I used two molex cables that had 6+2 pins that connects into the splitter that came with the GPU, one for one 6 pin slot AND the PSU pcie cable for the other. (This was while using Corsair CS650M PSU) So it powered perfectly fine and I updated the drivers, removed the old ones with DDU, etc etc. So when I went to test my card with Heaven 4.0, it did HORRIBLE.
Everyone with a gtx 1070 stock scored between 90-93 FPS, those who OC'ed it scored 100-105 FPS. As for myself? AN AVERAGE OF 47 FPS! What the hell? So I thought maybe the way it was being powered by two molex 6+2 pin and two regular 6+2 pcie cable, it wasn't getting enough juice. Since I didnt have a 2nd set of pcie cables on hand, I decided why not just upgrade the psu since I was to overclock safely. So I went today to buy a new Corsair cx750m, wired everything correctly, got two sets of the dual 6+2 pcie cables etc....
Well here I am, still scoring an average of 47 FPS. I dont know what to do anymore, this is on a fresh install of windows 10 (completely wiped everything last night to see if it would work, nope)
The new nvidia hotfix (368.95) doesn't seem to change its performance either.
ALSO, i did revert from windows 10 back to windows 7 for a day before wiping clean and fresh install of windows 10 because of problems from reverting, and this gtx 1070 was also scoring the same FPS rates on windows 7.
What gives? RMA? Did upgrading to windows 10 seem to screw everything up?
EDIT: Forgot to mention that sometimes after powering down (not restarting), when I come back to turn it on I sometimes get a pure black display. I then have to power off and on to get picture black.
I just installed a cooler Master hyper d92 on Saturday and it seems fine it idles at 35c. I will check when it's underload again when I get home from work
■ Hey guys, I'm back home. So I made an interesting observation right now.. I was removing the gtx 970 so I can put the 1070 back in when I noticed the latch that holds the GPU in the pci-e 3.0 in place is missing! Maybe that is what's causing my issue?
Am I able to connect it into the pci-e 2.0 slot (latches are there on those) or would I damage my card? Or would it get bottlenecked? Or would my motherboard be confused as hell? My motherboard is the MSI z97 gaming 5 so it has 2 additional pci 2.0 slots below the 3.0 slot.
Tman- stereo 3d is turned off by default for me
What's the Stereo setting then? I don't have that when I run it.
DUDE! This whole time I thought you were talking about the nvidia control panel sound setting loll
This did help out, just realized those are VR settings?
I just tried out TW Warhammer, benchmarks were at 70 FPS on ultra settings. Weird though, yesterdays test run before this 2nd fresh install was still stuttering for me. I'd like to thank all of you for your replies!
Heres what I did differently
Fresh install of windows 10 with media creation tool through flash drive.
Deleted all the partitions when asked, created new partition and formatted the primary drive
Installed latest BIOS and motherboard drivers
Downloaded DDU and uninstalled drivers in safemode
Downloaded latest NVIDIA driver for gtx 1070
When installing, clicked custom install, ticked the fresh install box, and had ONLY the driver update ticked. Didnt tick the rest of the drivers
Set nvidia control panel Power management mode to Prefer maximum performance
Changed the virtual memory setting to the recommended setting by windows
And thats it! Well I also swapped my card into the 2nd PCIE Slot, but I don't think thats a factor. Like I said guys, awesome! Thank you all and I hope this thread helps others out.
P.S. Tman, from your benchmark it looks like you're having problems as well?
Nice!
How has SLI been for you on windows 10?
I OC'ed my card, got an extra 7 fps out of it. Added +70 to GPU clock and +640 to mem clock
It's just this benchmark really. 270+ FPS on CSGO, max settings. No overclocks. i7 4770, GTX 1070 FE.
Games run fine, so no concerns here.
Edit: Just used DDU and did a clean install of just the drivers (no 3d vision, etc.) Results came out almost right on with your last result before overclocking (RamosL22)
