[SOLVED] Post code speaker not working
Nov 11, 2020
8
Hey, I recently installed a Post code beep to my Aorus ITX pro WiFi and it won’t beep. I was sure I had the polarity right. Did I ruin the header by screwing up the polarization?
Another late thought: Looked at the User Manual again - reference Page 30:
"HD Audio ControllerEnables or disables the onboard audio function. (Default: Enabled)If you wish to install a 3rd party add-in audio card instead of using the onboard audio, set this item to Disabled "
Setting?
Just to clarify: you installed a small speaker because the motherboard does not have a speaker - correct?
Motherboard link:
https://download.gigabyte.com/FileList/Manual/mb_manual_b550-aorus-pro-ac_1001_e.pdf
Referencing the internal connectors 13 & 14 (Page 20 of the User Manual)
Where did you get the speaker and how/where/ how did you connect the speaker?
What instructions or documentation did you use to install the speaker?
I bought sound original pc mobo internal speaker bios alarm buzzer off Amazon. I used the mobo manual to locat the speaker header polarity, but I think I was looking at the header upside down compared to what the manual was showing. I powered on the mobo and no beeps occurred. I tried flipping the polarity and posted again, and still no beep. I’m worried I either ruined the header by installing it incorrectly, or the header was bad to begin with.
Motherboard link:
Setting?
Setting?
I will see if I can disable it in the BIOS. Thanks
