Potential Upgrade Questions
Zuki_PC
Commendable
Dec 15, 2016
6
I wish to upgrade my PC as I don't get the fps that I truly want when playing games, what is the cheapest upgrade to my system that I can make that will provide a big increase to fps? Also I find that my games crash/provide errors due to not much memory yet I have 8GB, is that normal? I do not wish to do a completely new build btw as I can't afford that. Thanks in advance.
This is my system:
MSI Gaming 3G R9 280
FX-6350
2 x Corsair Value 4GB
ASRock 980DE3/U3S3
Coolermaster 600W Thunder Power Supply
Western Digital 500GB Hard Drive
Windows 10
the cpu is holding you back the most as far as fps goes. but to upgrade that will need a new mobo and ram which can add up. a better gpu won't do much since the cpu will be holding it back.
what kind of budget are you looking at? might be able to swing a decent upgrade if your budget is decent enough. probably $300 or so will get you an i5, mobo and 8 gb ram. maybe less if done right.
for example here is an i5, mobo and 16gb ram for $325
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor ($189.88 @ OutletPC)
Motherboard: Asus H110M-A Micro ATX LGA1151 Motherboard ($56.98 @ Newegg)
Memory: Mushkin Blackline 16GB (2 x 8GB)...
Memory: Mushkin Blackline 16GB (2 x 8GB) DDR4-2400 Memory ($78.99 @ Newegg)
Total: $325.85
Generated by PCPartPicker 2017-01-05 14:29 EST-0500
