Dear all,
It is time to upgrade my pc but since my lifestyle makes me move a lot lately I was looking to build something that could be smaller than a mid Tower, as such I was looking at a Micro ATX or Mini Atx format and ask the hive mind for help!
0) No need to be cheap for the case, I need one for the long term with a compact design that can be used for gaming!
1) I am upgrading the CPU so that is something we can change together with the motherboard, any suggestions?
2) Can we fit a tri-x 290 GPU in this small case, or if I would like to upgrade which GPU would you suggest? can we fit a 1070?
3) I do not want heating problems, best cooling solution? Water/Air?
Hopefully you can help this noob, in the meanwhile I wish you happy easter!
