Power line adapter for PS4
jrmeers4
Proper
Oct 9, 2018
90
I currently get about 50-250 ping sometimes 1000 if my family is on the internet, if I get a tp link av600 powerline adapter and a 10 foot cat 7 Ethernet cable how much lower will my ping be?
No problem, if you have any more questions feel free to ask anybody at toms, we're all here to help!
Be sure to pick a post as a solution so if anyone else comes searching for help with the same question, they know where to go 😀
It's honestly really hard to say, powerline adapters work better in some buildings better then others, it all comes down to how well the building/house is wired and how much electrical interference there is. In an ideal situation you would get almost the equivalent as running an ethernet cable directly to the modem. The closer you are to the modem/router the better.
You would need 2 powerline adapters to accomplish what you're trying to do.
The first one you would plug in near your router, then you would run an ethernet cable from the router to the powerline adapter in the wall.
The second one you would plug in near your ps4, then an ethernet cable from THAT powerline adapter to your ps4.
