G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.general (More info?)
Running Windows XP Tablet Edition on an HP Compaq TC1100 with battery icon in
system tray
Issues:
1. Power Management Options shows only two schemes (Portable/Laptop &
Home/Office Desk). The other schemes are missing. Unable to save a new
scheme. Disappears from list once program closed and reopened (with and
without a reboot).
2. Portable/Laptop scheme shows following error: Indicates two revision
levels are incompatible. (I tried saving under a new name - it showed same
error. Unable to delete scheme. Only disappears as in issue #1 above.) Afraid
to delete and reset due to issue #1 above.
3. When operating under battery power, screen goes off, but system NEVER
goes into Standby (nor Hybernate - which is enabled).
If I enter Standby mode physically (Start/Turn Off Computer/Standby) the
unit goes into Standby mode correctly. After the appropriate time the unit
even goes into Hybernate. Only when the unit is running does the failure
occur.
Possible related issue: The "Hide Inactive Icons" function under Taskbar and
Start Menu Properties no longer functions either. All icons display no matter
what setting chosen. I turned it off and rebooted, turned it back on -
nothing.
I'm dumbfounded by this. Any assistance is appreciated!
Thanks,
-j.p.
system tray
Issues:
without a reboot).
occur.
nothing.
Thanks,
-j.p.
