Power plug from monitor to PSU, where do I get it?
nchu1688
193
When hooking up your monitor, you use your graphics card to monitor plug, and a power plug. Does anyone know where I get the power plug? Does it come with the monitor? Or do I have to buy one?
looking at the monitor spec it uses a standard 3 pin iec kettle cable (the same as the psu)
I would wait till you recieve the monitor & psu, take the included cables to a local electronics/electrical/computer store & let them match them up for you
One for the PSU socket, and one for the monitor? And then we are good?
So, I should just go to a store, ask for a compatible corsair to my socket power cord for both the psu and the monitor buy those, and I'll be good?
Should I use standard or mickey mouse?
