Power Supply cable questions
Zombehh
214
Hi I am building my first pc and I got my PSU over the mail it is EVGA supernova 2 850w and it came with some cables I don't really understand where to install them
So I got:
A cable called CPU which I'm guessing goes on ATX_12V sonce it's 4x4 pin BUT on the box it says ESPS12v so I'm a bit confused…
Another one I got is MB which I know where it goes since its a 24 pin
I got VGA which its for the GPU right? I got 2 kinds of these one with 6+2, and complete 6 and the other has 6+2, complete 6 and another 6 pin on that single vga.
I got SATA for optical drive and Harddrive right?
I got one called PERIF which I don't really know where it goes… it has four 4 large pins (4 of them) and 6 pins but not 4 have actual pins the 2 are just black
And I got 2 adapters one seems to fit on the PERIF perfectly since its just 4 large pins
The other adapter is weird it has 24 pins I'm guessing for the MB cable and it has like a circle in 2 holes so it looks like a ring
These are my specs
http://pcpartpicker.com/parts/partlist/
(Replaced caviar blue with black)
Motherboard picture http://www.gigabyte.com/fileupload/product/2/4953/10057_big.png
ADAPTERS IDK ABOUT
First (for MB cable??)
http://i60.tinypic.com/111kx09.jpg
Second (for PERIF???)
http://i62.tinypic.com/9uatjp.jpg
1 x 24 Pin ATX.......... you know this one
2 x 4+4 Pin EPS12V...........2 of these come with it you only need one 4+4 for Cpu power
4 x 6+2 Pin PCI-E...............Graphic cards
2 x 6 Pin PCI-E..........Graphic cards
10 x SATA..........Optical , HDD , SSD etc.
4 x Molex.....Fans possibly other misc. devices
1 x Floppy....Hardly used anymore.
Honestly, if it fits or the cord specifically is marked CPU it will work. I have made multiple machines and never had a problem with this strategy.
I know this sounds like bad advice but it works like a charm
lol I guess you're right... As long as all cables are different I'll probably use your method
I own it the 850 G2 CPU power comes as a 4+4.
Woot! I think I know where everything goes now. Thank you so much Blackbird, Sorry I'm asking so many questions I'm just very excited. I have one more, I've heard people say that I should put the gel silicon bag (the one that says do not eat throw away) inside the case to prevent something I don't really remember what it did but I was wondering if it was a good idea?
