[SOLVED] Power supply comparison
Jan 10, 2019
21
Deepcool DE500W vs Corsair VS450 vs Thermaltake litepower 550W
Which is better for normal running I mean no overclockings or anything just run?
I'm on a tight budget now so I can't buy EVGA and other quality PSU.
So which is better?
What are your systems specs? That is something important to know.
All 3 should be avoided for any system that isn't an office pc and even then the deepcool should not be used.
How would I know it's a Gen2?
The gen2 has white accent colouring on it.
