Question Power supply destroyed my graphic card
Dusan Mldn
20
Hello guys a few weeks ago my power supply died.
More precisely, it burned down.When i changed the power supply my graphic card didnt give me a single and one ram stick didnt work.
I tried to connect GC to another computer with stronger power supply but it was the same.I even did a voltage drain to it but it didnt help
Any help would mean, thanks in advice
DSzymborski
Well, what are the specs involved, including both exact power supplies? Hard to say much about some mystery PC. And please be detailed about what actually happened and how you diagnosed the specific problem. I have no idea what "burned down" could possibly mean in this context.
Jan 21, 2022
46
You are right, you cannot just guess system specs and think that's what the specs are.
Also, "burned down PSU" can mean a lot of different things.
Dusan Mldn
20
The specs are
GPU: was xD R9 380x 4gb WINDFORCE
CPU:Intel(R) Core(TM) i5-3470 CPU @ 3.20GHz
RAM:4GB 1600MHZ early it was 8GB 1600MHZ 4X2
For the motherboard i am not sure beacuse i buyed the computer as a prebuild
The old Psu was SL-500a and it was 500w
And the new Psu is same
DSzymborski
Well, the PSU doesn't bode well; I can't find any reference to such a PSU and pretty much any PSU that's a complete mystery is garbage that risks frying your components (which might be what happened, you still haven't really described the series of events at all).
Do you have a picture of the chart on the PSU? It'll look something like this.
Reactions: maxamillionfeettall
Dusan Mldn
20
Here it is
I didnt say that my Graphic card isnt totaly destroyed it just dont want to give a picture
It spins and lights on side
awayagain
76
5
4,545
you kinda killing you're pc by you're own not the psu
you're pc need at least a 550w so it works properly
corsair cx650m or EVGA 600 BQ or thermaltake toughpower gx1 600w
these will provide enough power and stable current to you're pc
Reactions: Dusan Mldn
DRagor
Illustrious
Here it is
No wonder then. PSU was working close to/or over 100% all the time to power that GPU so it it was slowly cooking itself until it finally burned. And I really doubt it had proper protections so when it went down it probably took GPU down too. You said it was prebuilt - does it come with that GPU or you added it later?
Dusan Mldn
20
Nah the GPU comes with it
Yeah it took the Gpu and even one stick of ram
awayagain
76
5
4,545
Try the GPU in another pc
Since you said fans still kick in and lights are on
A pc that have enough watt power
Anyways dead GPU or not get a New PSU the corsair cx650m bronze will handle you're current system plenty
Or if you have enough money and aiming to upgrade further the pc in future
go for a gold one
Put avaible PSU's in you're région hère so WE help you chose one
Dusan Mldn
20
go for a gold one
I already tried it on a diffrent computed with better and stronger PSU
It still does the same thing
Thanks for help
I have one more question
Should i buy a 2gb graphic card and put it inside of this computer?
Jan 21, 2022
46
Here it is
Thanks for help
Yeah, replacing your GPU is a good idea.
awayagain
76
5
4,545
@Dusan Mldn it's not a question a 2gb will be enough it is about what you gonna use it for and
it is about are gpu's avaible in you're country like these one who died ?
are their prices good for you ?
DSzymborski
Thanks for help
And what is "better and stronger PSU?" It's important we know the actual PSUs we're talking about, not your vague description of them. To be blunt, you literally ran your GPU on a literal junk PSU and then bought the same junk PSU, so I'm not going to simply take your word that the other PSU is "better and stronger."
Simply put, we need facts. The scarcer the facts, the vaguer the answer. We're not psychics.
Reactions: awayagain
