Question Power supply is behaving weird, PC turns on but after shutdown it doesn't!
Oct 15, 2022
8
So, I recently bought a used 750w power supply for a cheap price. I didn't need this much power but still it was a good deal. I paired it with my pc it was running smoothly but yesterday my pc wasn't turning on, so with the help of youtube I tested the power supply by shorting the motherboard cable and the psu was running . Then, I connected it with my pc again and it turned on but when I shut down the pc it wasn't turning on again. So, I removed the cables and connected it again it powers on once or twice at max then it doesn't turn on again. So, I connected my pc to another psu which is very low powered and doesn't come close to this psu, and the pc was running smoothly on it. I should mention my pc currently doesn't have a gpu installed.
The Power Supply in question: Cooler Master MWE 750 V2 80+ Bronze
My setup:
Ryzen 3 3200g
Gigabyte s2h b450m ultra durable
4+4 2666mhz Ram
240 gb ssd + 1tb Hard disk
Bronze 230v eu
That's a cheap one anyway. Must be almost for free when you got it used.
also there's 80+ bronze rating!
It only tells you something about the efficiency of the unit, nothing about quality and protections. MWE Bronze V2 230v EU is a budget unit with very basic input filtering for 200-240v mains only.
Reactions: Roland Of Gilead
