Power Supply // Motherboard // Processor question regarding a wire that came with power supply.
reedturman
14
Hello, I just purchased a fully modular Power Supply, which replaced a semi-modular one. The wire to power the processor that came with the fully modular PSU is different from the wire I used from the semi modular.
The semi-modular PSU had an 8 pin and 2x 4 pins for the processor, and my motherboard has a slot for a 4 pin and an 8 pin to power the processor. So I plugged an 8 pin in, and a 4 pin in, and was left with one 4 pin remaining.
The fully modular wire for the CPU only has only 8 pin to the 2x 4 pins, and no 8 pin to 8 pin. My question is, how do I properly plug into a motherboard with a 4 pin and 8 pin receiver when I have 2 4 pin male ends??
Old PSU : Thermal Take 875w XT
New PSU : EVGA 850w SuperNova G2
Motherboard : z87x-OC gigabyte
Processor : i7 4770k
Connectors
1 x 24-Pin ATX
2 x 4+4-Pin EPS12V
4 x 6+2-Pin PCI-E
2 x 6-Pin PCI-E
10 x SATA
4 x 4-Pin Peripheral
1 x Floppy
That PSU has 2X 4+4pins for the CPU and they plug into the power cupply where it says CPU1 and CPU 2.
One cable 4+4 pin to the 8 pin and the other 4+4 pin to the 4 pin leaving the other unconnected just like the old power supply.
Connectors
1 x 24-Pin ATX
2 x 4+4-Pin EPS12V
4 x 6+2-Pin PCI-E
2 x 6-Pin PCI-E
10 x SATA
1 x Floppy
Thank you for the reply both of you. Glad to know what the options are, would mark both for the solution if I could.
I ended up using 1 8 pin on CPU 1 to 2x 4 pin cable without the extra wire, as I am not overclocking at this time.
A new issue has emerged, although far less serious (I hope). My PSU fan is disturbingly loud for being new, it is powering a 1070 TI, but other than that nothing is terribly high end. I've listened to videos of just the PSU turn on and it sounds similar, but mine sounds a little more "clicky" like a processor. When I can upload a video to youtube of the sound I'll create a new thread for the noise. Considering it's a large case with lots of fans, the noise could be being amplified, but the PSU fan definitely seems loudest.
PSU fan shouldn't be loud. If you are 100% sure its the PSU and loud, then I would exchange it.
