power supply only has one 6pin I need two for XTX 6850 Radeon
Hey guys i have a Thermaltake TR2 W0070RUC 430W Power Supply it only has one 6pin and I need two for my XTX 6850 Radeon card. I looked into it some and since I dont use the molex connectors I noticed there was two leads coming out of the PSU. I went ahead and measured the volt and it was at 12v just like the 6pin. I then took a old power supply unit and cut the motherboard connector so I had a 6pin.. then one row was all 12v and the other row of 3 was ground... It worked but is there anything I should know about this being a bad idea? I didnt know what the molex connectors supplied as far as amps. Output was listed as:
+3.3V@20A, +5V@24A, +12V1@14A, +12V2@15A, -12V@0.3A, +5VSB@2A
I did have to cut the corners on the inside pin so it would fit the 6pin for PCI-E.. razor blade FTW
Let me know.. thanks!
wired like this (two grounds to one at the 6pin. Then two molex grounds to the two left at 6pin.
ground ground ground ground (molex)
-----ground------ground ground
Then one power at molex to two at the 6pin... then the last power at molex to one at 6pin
___power_____power (molex)
power power----power
http://oi46.tinypic.com/abo8s6.jpg
