R Revster7k Honorable Dec 23, 2013 22 0 10,510 Jan 30, 2014 #1 So i've got a 600w corsair psu and was wondering if it would handle a fx 6350 a 7870 ghz edition, 1tb hdd and about 6 120mm fans + perhaps NZXT HUE, for lightling. Thanks!
H HeyyScott Honorable Oct 9, 2013 863 0 11,360 Jan 30, 2014 #2 It should work but the large quantity amount of extra fans and LED light worries me. Can you tell me which fans and led you're using. Upvote 0 Downvote
R Revster7k Honorable Dec 23, 2013 22 0 10,510 Jan 30, 2014 #3 Just the standard fans from nzxt, i've got a phantom 410 you see and it already contains 3 so i just want to improve intake and exhaust, but i would drop it to 2 extra + the HUE, ofc only if the psu can handle it 😀 LED- http://www.nzxt.com/product/detail/98-hue-case-accessory Fans- http://www.nzxt.com/product/detail/86-fn-120rb-case-fan Upvote 0 Downvote
H HeyyScott Honorable Oct 9, 2013 863 0 11,360 Jan 30, 2014 Solution #4 Yeah, I'm sure you will be fine. Upvote 0 Downvote Solution
aevm Illustrious May 18, 2007 11,974 0 41,960 Jan 30, 2014 #6 You'll be fine. http://www.guru3d.com/articles_pages/amd_radeon_hd_7850_and_7870_review,7.html Upvote 0 Downvote
