Power Supply Question
banesong
43
Has anyone used PowMax? I am curious on reliability. I need approximatly 370W (ie a 400W) and am balking slightly at the cost of an Enermax.
with cost comes quality...
if u get an enermax u wont regret it.
(proud owner of a 550W monster)
(friend has 430W whipser that cured his constant crashes)
Is that a Northwoody in your pocket or are you just eXPited to see me?
A Leadman POWMAX is a good, reliable power supply. Enermax may be better, as LHGPooBaa mentioned, (mostly because of the positioning of the dual-fans and the noise reduction) but there is absolutely nothing wrong with a Leadman. I use them quite a bit.
Toejam31
<font color=red>My Rig:</font color=red> <A HREF="http://www.anandtech.com/mysystemrig.html?rigid=6847" target="_new">http://www.anandtech.com/mysystemrig.html?rigid=6847</A>
____________________________________________________
<font color=blue>"Does history record any case in which the majority was right?" ... Robert A. Heinlein</font color=blue>
I believe that's what I have. A 500w powmax. The core is Leadman. They market it as a Powmax. The fan is a straight blow through, unlike the Enermax, which pull a certain amount of air directly off the cpu hsf. The layout is called nATX, or something like that. If you don't have any other fans in your case, or are missing a blowhole above the psu, then it might make a difference aircooling. Psu's are made to take some heat.
Anyway, mine does good with a 1.4g a7v133. With power to spare (heh).
$74 with s/h.
Rich is the nation that has many war heroes. Long since forgotten...
