Hello everyone,
I am in the process of gradually upgrading my PC. My current specs are as follows:
Intel E4500 @ 2.8GHz with AC Freezer Pro 7 cooler
ASRock 4 CoreDual-SATA2
533MHz DDR2 2GB RAM
ATI Radeon 9800 Pro 128MB AGP
3 SATA and 1 IDE HDDs
Creative Audigi 2 Value PCI
One PCI SATA Controller card
One PCI Firewire card
Plextor DVDRW Drive
USB Card reader
One Powered USB HUB
Logitech PS2 Keyboard and USB Mouse
A 2GB USB 2.0 Flashdrive (Stays plugged in mostly)
Occasional USB connection to Mobiles, PDAs, USB Scanner etc.
Thermaltake Lanfire Xaser III VM2000A Case With Fan-Controller and four 90mm Fans
Antec True Blue 480W Power Supply
My plan was to gradually upgrade my graphics card (to ATI HD2900/2950 Pro or a Nvidia 8800GTS), then a better motherboard from ASUS or ABIT and finally my eyes were set on the Antec P182 Case.
But my current rig has been doing a few odd staff even at stock CPU speed. After a bit of research, I've figured out that I have been overlooking a vital component of my setup and that is my power supply. The PSU calculator at Antec's website tells me that with my current set-up should need 500+ Watts. and with my planned upgrades, I probably will need a minimum of 700 watts, specially if I go for an ATI card. But reading around various forums, I wonder if I really need that much power. Also When I get the new graphics card, I will definitly need a new PSU as my current one has no PCIe connectors.
Keeping my planned upgrades in mind, may I request some suggestions for a good ATX PSU which is quite and is going to keep me going for at least 3 to 4 years? Any and all help would be greatly appreciated. Thanks in Advance.
- dmarook
533MHz DDR2 2GB RAM
Plextor DVDRW Drive
USB Card reader
One Powered USB HUB
- dmarook
