hoping someone can help ive serched evrywhere online and cant find a problem exactly like mine and what i do find nobody has a solution for.
due to lightning my computer fried and im replacing everything with what i can afford.
biostar ta970 motherboad (so far turning out to be a huge p.o.s)
amd fx 8320 8 core overclocked to 4.4ghz
16gb ddr3 ram at 1600
228gb solid state drive
2 2TB hhd
msi r9 390 8gb graphics card
xion 630 watt power supply
windows 10 pro
it runs fine just web browsing, youtube, downloaded movies. but as soon as i launch any game doesnt matter what from minecraft to gta5 it imediatly crashes the whole computer led light go off in the case and i have to unplug it and hook it back up before it will start again. ive tried underclocking the gpu and going back to factory 3.5 clock on cpu to no change.
however if i swap out the graphics card with a radion rx 560 4gb it will launch every game with no problem.
swapped out the psu with a coolmaster 600 watt and same thing with the bigger grapgics card.
my question is, is my computer just overloading these power supplys and i just buy a lot bigger one or could something else be at fault? please help id love to use this better graphics card.
2 2TB hhd
windows 10 pro
