G
Guest
Guest
Greetings all!
I was building a new AMD system (my first) and believe I may have blown up all my computer components 🙁 I installed the mobo (Asus A7A266), cpu (Athlon 1200 - AXIA), & ram (256 mb Crucial DDR). Fortunately, I did not install the ASUS GeForce 3 Deluxe, IBM Deskstar 75GXP, or any other cards. I wanted to start with the mobo, cpu & ram. Once installed correctly, I attached the power cord and noticed the mobo led lit up. I then pushed the power button and the system jumped to life. Suddenly, I noticed the distinct smell of burning circuitry. Immediately I pulled the power cord (within 30 secs). After checking that the voltage jumpers were set to auto on the mobo, I happened to notice the red tab on the power supply was set to 230v!!! I know it should be set to 115v for North America. My question to you is, did I destroy the mobo, cpu, & ram? A friend who is a network specialist stated he thought I may have just buggered the power supply and the other components should be ok because the mobo wouldn'd allow the voltage. Any input is appreciated!
Thanks in advance!
SHODAN
Thanks in advance!
SHODAN
