M mailmekotgireamol Honorable May 16, 2012 3 0 10,510 May 16, 2012 #1 my motherboard light is on but other compnants no power supply and my processor fan 1 second start and then off or stop
WR2 Polypheme Nov 18, 2005 27,923 6 64,715 May 16, 2012 #2 All you know right now is PC did not complete POST (power on self test). It might be the power supply. But it could also be some other problem. ->No way to tell from your description what the problem is. Do you hear any beeping? Upvote 0 Downvote
WR2 Polypheme Nov 18, 2005 27,923 6 64,715 May 16, 2012 #3 Computer POST and beep codes http://www.computerhope.com/beep.htm If you computer does not have a motherboard or case speaker you may need to get one. Check your motherboard manual. How can I disable or enable the internal speaker? http://www.computerhope.com/issues/ch000725.htm Motherboard speaker: http://www.newegg.com/Product/Product.aspx?Item=N82E16812201032 Upvote 0 Downvote
WR2 Polypheme Nov 18, 2005 27,923 6 64,715 May 16, 2012 #4 POST troubleshooting steps http://www.computerhope.com/issues/ch000607.htm Upvote 0 Downvote
