It IS possible.Nikola Tesla just rolled over in his grave. Its not impossible, per se, just infinitely impractical.
Now...bring it to market at a reasonable price, and effective performance.
Ill grab my encabulator and go to work.It IS possible.
Per usb c cable you can run two of those....although why you ever would I have no idea. Most fans are nowhere near that nor should they be. Maybe for a server system but for a desktop that is just silly.I have a Delta PFC1212DE-F00 120x38mm fan that can draw 4.8A (@12V) on start, but it's a finger-chopping screamer.
Air cooling is proportional to the density and mass of air being directed, increasing the velocity of the air (even without increasing the mass of air) increases the heat xfer coefficient. Go big or go home.Per usb c cable you can run two of those....although why you ever would I have no idea. Most fans are nowhere near that nor should they be. Maybe for a server system but for a desktop that is just silly.
Enterprise can get away with "similar" connectors because they are indeed built with the tolerances and rigour you'd expect. I do not trust Asus and the people behind the BTF group/forum to design something as safe and proper as enterprise-grade hardware.Hot swap server PSUs running at 1kW or more use similar connectors. This isn't a new idea and it works just fine in those cases. They are essentially using the same idea here. Assuming they are using similar quality connectors. The one picture there looks a lot like an ISA slot.
But server chassis are very proprietary as is something like this. I like the general idea of making the cabling more simple and easier to work with. But I do think this PSU idea is going to far into the proprietary and non-customizable PC configurations. If, like this, a motherboard put all of the power connectors on the edge of the front of the motherboard at 90 degrees, then cable management would be much easier already without having to require the PSU to be up front like they have it.
Good point ...and since PSU is beside motherboard not on top or bottom of it, it is both top-less and bottom-less at the same time.I think this article is mis-titled. This new formfactor is 'cable-less', not 'wire-less'. What is the difference? Wireless power brings up thoughts of power thu the air. This is not that.
How much 12v power does USB port provide = 0W <-- USB is a 5v interface. You cannot power the fans with USB ports.
Someone mentioned outdated JDEC specs <-- JDEC specs are used for DIMMs and nothing else in the PC, so JDEC is not part of this new proposal.
Aquarium pumps have been doing this for years. Electrical stuff outside the glass where is stays dry and impeller with magnets but no electrical components inside where it's wet. They transmit through 3/4" glass no problem.A wireless chassis fan is a nice idea but the EMF strength required to power it wouldn't be.
5 amps, so 60 watts at 12v. Plenty of power for any fan or even spinning hard drive. I would expect any latency sensitive storage to be relatively small and easy to fit on m.2 cards. Today, sata seems to be used for bulk storage where latency doesn't matter as much.How many amps of +12V power can a USB port provide? You have to remember that larger fans, when they spin up, draw much more power than when they're already spinning.
While SATA3 might not have the bandwidth over the latest iterations of USB, I believe the latency is superior.
How much current draw and at what voltage do they operate? Let's see some examples.Aquarium pumps have been doing this for years. Electrical stuff outside the glass where is stays dry and impeller with magnets but no electrical components inside where it's wet. They transmit through 3/4" glass no problem.
Sure thing. Vortech was first to really push the tech (though many others have jumped onboard). Let's use the MP60 as an example since that's their most popular model over the years. It's tunable to use between 10 and 60 watts, runs on 12v and is kinda famous for being able to work for many hours off a car battery in the case of a power emergency. Don't let the price bother you as this is a niche product for a niche industry. There's nothing overly exotic in the construction.How much current draw and at what voltage do they operate? Let's see some examples.
Cool bro platitudes but that is a very inefficient ridiculously loud fan. It is way...WAY out of the norm. You are using something like 40 times the power to push 4 times the air. It probably does have a high pressure but all of that comes with issues as well. So if you want to cool a mining machine you go with something like that, if you want to cool a computer that won't sound like a hairdryer sitting next to you get a number of noctua fans.Air cooling is proportional to the density and mass of air being directed, increasing the velocity of the air (even without increasing the mass of air) increases the heat xfer coefficient. Go big or go home.
As you said this is off subject but a correction.You are using something like 40 times the power to push 4 times the air.
The board makers have all of the power, USB, SATA, speaker, PWR/RESET.... connectors that other motherboards have - they just put them on the back. Plenty of cases work very well with the limited number of boards using BTF or BMD designs. The only thing that plugs in to the front or side of the board is the CPU, RAM, M2, and PCIE. No visible wires. Currently the GPU is likely to have a visible wire, but all that is required to correct that is for AIB GPU partners to offer SKUs that the power ports are moved to the PCIE connector edge about 10" from the metal back that is screwed into the slot on the case.". It has only 1 PCIe slot, that meant for the video card. The back panel is not visible but I will assume it has 1 or more USB/Thunderbolt ports for connectivity to external devices. The demonstratable expansion capabilities are less than my old Amiga 500. Assuming the motherboard has integrated audio and video, I recommend using that one PCIe slot for other purposes than a video card.
I just compared the CFM listed on the two fans, and their power usage. I don't know the physics on it, but I think the higher you go in the same size fan you will have a huge reduction in efficiency for all sorts of reasons from drag, to pressure, and turbulence.As you said this is off subject but a correction.
Unless there are major electrical or more likely mechanical energy efficiencies such as bad bearings, he would be using 16x power. Wind force is a function that squares with the surface area moving it or it is moving.
How well does this inductive motor would when its EMF generator is 2 or 3 feet away though? I'll bet it doesn't work at all.Sure thing. Vortech was first to really push the tech (though many others have jumped onboard). Let's use the MP60 as an example since that's their most popular model over the years. It's tunable to use between 10 and 60 watts, runs on 12v and is kinda famous for being able to work for many hours off a car battery in the case of a power emergency. Don't let the price bother you as this is a niche product for a niche industry. There's nothing overly exotic in the construction.
They aren't inductive. It's simply a rotating magnetic field on one side and permanent magnets on the other... and yeah magnetic fields diminish rapidly with distance. To throw a magnetic field 2-3 feet, you'd need 10's of kilowatts (think MRI machine), and good luck trying to spin a fan at that distance.How well does this inductive motor would when its EMF generator is 2 or 3 feet away though? I'll bet it doesn't work at all.
Magnetic fields are subject to the inverse square law. This one of many reasons we have multiple radio towers and cellphone's towers everywhere instead of just one giant one in the middle of the country. The power required for doubling the useful distance is a lot.They aren't inductive. It's simply a rotating magnetic field on one side and permanent magnets on the other... and yeah magnetic fields diminish rapidly with distance. To throw a magnetic field 2-3 feet, you'd need 10's of kilowatts (think MRI machine), and good luck trying to spin a fan at that distance.
