Hello everyone,
I picked up a reference PowerColor RX 7900 XTX from Micro Center, I have 13 days left to return it, I've been trying to make sure my card is not affected by the junction temperature problem.
As you can see [Image for reference included below] GPU temps never went above 82 C, this is after running GTA V all day and doing 3D Mark Time Spy multiple times through out the day. GPU hotspot never went pass 105 C but the junction Temp did hit 110. As far as the clock the card fluctuates between 2400mhz and 2690 on occasions but it will not throttle below 2400. btw fans are not maxing out, im running them between 1000 rpm and 1600 rpm as that's bearable, at 100% the card is too loud.
My highest 3D Mark score on GPU only is 30,506 and my lowest on the GPU as well has been 28,635. If they had not made the report about this issue I'd probably think that I have a poor silicon lottery picked and that's why the card can't clock any higher but than again if it was really damage wouldn't it thermal throttle more aggressively? for context the rest of my system is as follows: Part List
