G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.device_driver.dev (More info?)
Hi,
I have bought a new printer, and when I switch on the PC, or switch
off the printer, the following messages are being given.
In the taskbar -
Found new hardware
hp deskjet 4320 series
A dialog box opens and gives -
The file 'hpzimc05.dll' on (unknown) is needed.
Type the path where the file is located, and then click ok
Copy files from:
f:\enu\drivers\win2k_xp
I have given the WinXP cd to try to install the required dll, but it
was not found. Also the printer works ok.
Can someone help me figure the problem out.
Thanks in Advance
Hi,
In the taskbar -
Found new hardware
Copy files from:
Thanks in Advance
