Printer will not load
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.print_fax (More info?)
I have a Dell XPS Gen 2 running XP Home SP 2 and about 6 days ago when I
truned it may printer wouldn't work so I got a new one its a HP Officejet
5510 All-inlone, now when I try to reload the CD I get a error message
"Officejet 5500 (USBHUB) cannot load printer. Dell said it was HP probelm
and after 5 hours on the phone with HP they said its a Dell problem and I
need USBHUB.inf reloaded. The printer works fine on another Dell PC and I
even tried to load a dell All in on 960 and got an error message no plug n
play hardware found. Can anyone give me any solutions to this problem??? Jon
Are you trying to install the printer to a USB hub? If so, is it powered or
unpowered? Are you sure it is 'seen' in the Device Manager correctly?
Cari (MS-MVP) Windows Client - Printing/Imaging and Hardware
www.coribright.com
"Jontman" <Jontman@discussions.microsoft.com> wrote in message
news:B172F61D-4136-47C3-A324-4A8A49F99A5A@microsoft.com...
> Jon
I'm just plugging it into the USB outlet, the Devise Manager dosen't showits
connected but if I plug another devise into the same outlet it works fine.
The printer worked until 7 days ago and I had to replace it (with the same
model).
> www.coribright.com
> > Jon
