Printer Wizard not starting
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.print_fax (More info?)
I have tried to install an HP 970Cse on the parrallel and the USB port, both
instances I get the error "Cannot install this hardware" "There was a problem
installing this hardware" "hp deskjet 970c series" "An error occurred during
the installation of the device" " The specified procedure could not be found"
I downloaded the XP Driver from HP's website and ran the installation
program, the print spooler is running, the found new hardware wizard also
tries to install this printer and i get the same error. I cannot start the
"Add Printer Wizard" even if the printer is unplugged.
Are you logged on as an Administrator or a User with Admin Rights?
Have you tried checking your System Files to see that all are happy... from
the command prompt, type
sfc /scannow
(note the space between the c and the /)
Cari ((MS-MVP Printing, Imaging & Hardware)
www.coribright.com
"rflehto" <rflehto@discussions.microsoft.com> wrote in message
news:B4EB36BB-E6F8-463C-A8DA-E6FE55CB2347@microsoft.com...
both
problem
during
found"
Yes, I have administrative rights, and Yes, I ran sfc /scannow, and no
problems were found. This system is only a few days old, and I had just
installed my companies programs (Office, Notes, etc.) that they use on a
daily basis. the first thing being virus protection. The only other things I
had installed were Microsoft's patches.
I finally had to run a system restore, to a point prior to installing all
the patches and all my programs. Thankfully I had a backup of all my data
because when the system restore is run, some programs that wern't installed,
at the point that I had to restore to, deleted the data folders as well.
> sfc /scannow
> www.coribright.com
> both
> problem
> during
> found"
Try disabling antivirus before you reinstall.... and check nothing has
actually been installed first as per
http://www.coribright.com/windows/Article%20One.htm
www.coribright.com
news:1D18C29A-6A0C-488D-B11A-91475F422D71@microsoft.com...
I
installed,
from
> > sfc /scannow
> > www.coribright.com
port,
> > both
> > problem
> > during
> > found"
also
the
This is a brand new system, not an upgrade to an older operating system, so
the article you referred me to didn't help. The printer was never installed,
so I could not see any printers in the printer folder. Also I could not get
any information about the Printer server properties.
I could not even install a networked printer. The "Add Printer Wizard" was
somehow creating the problem, as I could never finish installing the printer
from the "New Hardware Found" wizard, either. Whenever I re-booted, the
Hardware Wizard found the printer, but every time it would give me the same
error. I even tried to cancel the Hardware Wizard, and install from the
Printer Wizard, but the Printer Wizard would never start.
I finally used the System Restore to fix the problem.
> www.coribright.com
> I
> installed,
> from
> > > sfc /scannow
> > > www.coribright.com
> port,
> > > both
> > > problem
> > > during
> > > found"
> also
> the
