• Enter here for a chance to win a custom MechWarrior 5: Mercenaries themed PC powered by Intel!
Question Problem after build
Apr 3, 2021
4
Hi everyone!
So after 10 years i decided to build another PC. Unfortunately it won't boot up. When i power it on the fans spin for a second and then turn off only to turn on again in a endless loop while the CPU LED flashes on the motherboard.
I've checked the PSU by doing the paperclip test and it seemed to work (the fans kept spinning). So i decided to flash the bios. It did for 5 min or so and while it was updated to the lastest version all the fans continued to spin, i saw the LED of the GPU turn on,..so i was hoping everything would work after that. The CPU LED stayed on while updating the bios. After it was done the same problem started again.
Does anyone know what the issue might be?
I have a gigabyte aorus pro ax z490 with a i7-10700k
Apr 3, 2021
4
AORUS Z490 PRO AX
Noctua NH-D15
Intel icore i7-10700K
Gigabyte RTX 3070 gaming OC
Fractal Design Define 7 Light Tempered Glass tower
ASUS BC-12D2HT Silent blu-ray combo
Corsair 32 GB DDR4-3200
Seagate Firecuda 520 1TB SSD
Seagate ST2000DM008 2TB HDD
Corsair gold rm850
Extra fractal gp 14 fan
