Problem as rock h97 anniversary
riku925
Commendable
Jun 15, 2016
6
Hi i have a problem with the motherboard asrock h97 anniversary, this mobo don't read the vga Asus stix 960 gtx 2gb why? Thanks
Since none of the other mods are helping (yet), I'll try my best to see if I can help.
So to make sure I have everything correct, the GTX 960 doesn't work in the main computer, but works on the other two PCs correct?
If so, make sure your BIOS is up to date. Go to ASrock.com and check for a BIOS update. You'll have to go into your own bios to see what bios number it has.
Yes i have connect the power cable, and i test the vga in other pc and the vga work in other pc, i have a 750 watt power supply.
I changed the motherboard with another h97 and the problem is still there, I can not understand what is the problem.
I use windows 10, i have tested my vga in other pc and it work, and i tested another vga in my pc and it work, but my vga doesn't work in my pc.
Thanks for your help the problem was the bios update , now works all, thanks .
