problem buying GPU
Voxxie
21
So, I want to buy a good gpu that could run GTA V, BF4, BF3, DayZ SA, Far Cry 3 with good frame rates on 1080p. Im not a rich guy, so i'm looking to mix with fx-8320
Im not an expert in graphic`s cards things and i cant decide which gpu is the best for me to buy from these listed below -
MSI GTX 760 Twin Frozr 2GB
Gigabyte R9 270x 4GB OC edition
GTX 750 Ti Zotac 2GB
Which one from these cards should i buy? which is the best of them?
Maybe you can suggest me other cards, but im not of of the richest guys arround.
(sorry for my english)
Well the 760 and 270x are pretty much on par with each other the 750 ti is the weakest of the 3. I woud suggest the 760 its what i have and its been flawless for me so far. If you want tell me what country you live in and where you plan to order your parts and i might be able to help you come up with something better for a similar price.
Ignore GTX 750ti if you want good frames @ 1080p in those games.
Though the other two cards are considered neck to neck in performance only in the case of both cards having same VRAM. But here we have a 2GB GTX 760 vs 4GB R9 270X. So in this case the R9 270X would give you better performance then the GTX 760.
If both costs the same, in where you live. Grab the R9 270X 4GB. And I would suggest this model:
Core/Memory:
1030MHz Core (Boost Clock:1120MHz) (OC mode)
1030MHz Core (Boost Clock:1080MHz) (Gaming mode)
1030MHz Core (Boost Clock:1050MHz) (Silent mode)
4096 GDDR5 5600MHz Memory
Video Output Function:
Dual-link DVI-I x 1
Dual-link DVI-D x 1
HDMI x 1 (version 1.4a)
DisplayPort x 1
Cheers!
