problem finding program on drive
MikeK
20
Archived from groups: microsoft.public.windowsxp.newusers (More info?)
Looking at the ADD REMOVE facility on my PC I found some program called
"mini golf master special edition". It is about 65MB in size and I had no
idea that it was even on my computer. I would like to remove it but want to
run it first. Problem is, I can't find it! Is there an obvious way to
locate this program?
Try searching for the program: Start\Search
Before you open that program do a complete antivirus scan with the latest
updates.
Mini Golf Master is available at: http://play.ign.com/objects/536/536026.html
