S sybaris Reputable Mar 20, 2014 8 0 4,510 Mar 7, 2015 #1 The only thing I have on this MB is power, 1 stick of RAM, 1 system fan, the CPU and the case on/off switch. Depress the switch and sys fan spins for a second and some red lights flash. I have reseated the RAM still no joy. What next? thanks
Solution alexoiu Mar 7, 2015 Are both 24 and 8 pin power cables connected? If yes, start the board with only CPU and CPU fan installed. See if the CPU fan does spin.
alexoiu Titan Nov 1, 2012 39,818 250 126,990 Mar 7, 2015 #2 As it looks like a short, try testing the board outside the case. Check if the standoffs are in the right spots. Upvote 0 Downvote
geofelt Titan Oct 9, 2006 54,426 4,199 174,240 Mar 7, 2015 #3 Sounds like a ram issue. Is the ram installed in the recommended slots? Try using just one stick in the recommended single stick slot. If no joy, try the other. Upvote 0 Downvote
J jimpz Distinguished Jan 20, 2012 802 0 19,360 Mar 7, 2015 #4 Possibly, the mobo you have does not have the latest bios, which is needed for that CPU. (7917v12) http://us.msi.com/support/mb/Z97-GAMING-5.html#support-cpu Upvote 0 Downvote
S sybaris Reputable Mar 20, 2014 8 0 4,510 Mar 7, 2015 #5 alexoiu : As it looks like a short, try testing the board outside the case. Check if the standoffs are in the right spots. took the board out of the case, moved the RAM around using combinations of sticks and slots....... same indications. Bad board? Upvote 0 Downvote
alexoiu Titan Nov 1, 2012 39,818 250 126,990 Mar 7, 2015 Solution #6 Are both 24 and 8 pin power cables connected? If yes, start the board with only CPU and CPU fan installed. See if the CPU fan does spin. Upvote 0 Downvote Solution
