Problem installing firewire card
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
Hi,
I have been trying to install a combo Firewire/USB 2.0 PCI card with out
any success !!! After i insert the PCI card in an available PCI slot and
restart my machine, it hangs after showing "New hardware found" msg in
taskbar. When i reboot the system again after removing the card, sytems
goes back to normal. I have tried 3 PCI slots (one as already in use by my
modem card) and it does not make any difference. I understand that Windows
XP has built-in support for firewire/USB cards but it seems windows is not
able to install drivers properly .. I have installed card manufacturere USB
drivers as well.
My system info:
- Intel Pentium 4, 1.60 GHz
- 256 MB Ram
- Windows XP Service Pack 1
Firewire/USB card: IOGear GUF320
GO back to the store and get another brand of card.
Explain your problem, they are sure to oblige. Or else they must give you
your money back.
"jwalker" wrote:
> Hi,
> drivers as well.
> My system info:
> - 256 MB Ram
