problem installing W7 on a SSD
foxfan
21
my friend have a problem installing w7 on a ssd, well that exact same ssd had w7 installed but somehow he mannaged to disconnect the power from the ssd and all the data got lost somehow, well we formated the disk to be sure and it should be all fine and good, but stil it wont install w7, its stuck on 0%
we have tried disconnecting all other sata devices including hdd's and so on( not the dvd reader ofc)
we have tried disabling smart modes and so on, we have tried everything we could find on any formum and we are running in ACHI mode( think it was called that)
hes using a Asus maximus VI formula motherboard if that helps in any way
foxfan
21
we also tried disconnecting the USB 2 and USB 3 hubs, heard that might couse a problem. but it didnt help, i bet there is something in the BIOS or something
Secure Erase the SSD to restore it to a blank, fresh-out-of-the-box condition.
See page 3-50 of your motherboard manual for instructions on how to SE your SSD.
Also FYI, your motherboard has 10 SATA 3 (6Gb/s) ports.
Connect your SSD to one of the Intel 6Gb/s ports, not to one of the ASMedia 6Gb/s ports.
Also, after you SE the SSD you don't have to format it. Let Windows format the drive automatically during the installation process.
