problem of sending international fax by using calling card
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.print_fax (More info?)
I could use my XP Fax to send or receive local fax, in addition to
receiving international fax. However, I failed in sending international fax
using calling card. Both of my fax number and the international recipents'
were given rightly, such as
+1(613)xxxxxxx, and I logged on my laptop as administrator. In addition, I
could hear four to six phone rings and then two fax rings from the
destination fax by my phone (both the calling card and the destination fax
were confirmed to be OK). Unluckly, the XP Fax monitor finally showed that
there was no answer. The calling cards I used are CiCi and Jia phone cards.
(Canada)
I viewed all the posts under the search of "calling card" in this
discussion group, without finding the answer. Problem may originate from
the phone cards themselves (they may not support XP Fax) or from my wrong
setting in somewhere. I tried many times but the results were always the
same. Could anyone give me some suggestions for resolving this problem?
Thanks in advance!
Best wishes,
spinsight
If your Calling card settings are part of the per-user settings, you are out
of luck with Windows XP Fax. The XP Fax Service can only run under the
System account, so per-user settings are not available to it. Here is a
somewhat cumbersome work-around one user came up with:
Under general "dialing rules" in the "to access an outside line for long
distance calls" box, use one very long prefix:
<calling card telephone #>,,,,,,,,<1 (for English, if required)>,,<PIN>,,
Each comma shown gives a 2 second delay, to allow for the required delays
when calling in. You may have to adjust the commas until you get the proper
delay. Also, I listened to my speakerphone during this procedure. It
really helped in setting up the FAX prefix.
Also, if the FAX telephone number fails, and the calling card message says
that was an invalid telephone number, it may still be possible to recover
(if the modem doesn't time out) by quickly dialing the FAX number manually
on the telephone keypad.
Hal
Hal Hostetler, CPBE -- hhh@kvoa.com
Senior Engineer/MIS -- MS MVP-S/U -- WA7BGX
http://www.kvoa.com -- "When News breaks, we fix it!"
KVOA Television, Tucson, AZ. NBC Channel 4
Still Cadillacin' - www.badnewsbluesband.com
"spinsight" <spinsight@discussions.microsoft.com> wrote in message
news:F301C4A6-4BA3-4C73-9F19-85FE40C2928C@microsoft.com...
> fax
> recipents'
> I
> that
> cards.
> (Canada)
> Thanks in advance!
> Best wishes,
> spinsight
Hi, Hal:
Thanks so much for your instruction. However, after doing these, I still
have the problem. There is no question to proceed the dialing rule of
calling card, since I could hear the fax rings from destination, which is the
same as dialing directly by voice phone. In addition, I could fax to an
international destination without using calling card. So, same questions
remained: were they originated from calling cards or from wrong setting?
Sincerely,
Spinsight
> Hal
> > fax
> > recipents'
> > I
> > that
> > cards.
> > (Canada)
> > Thanks in advance!
> > Best wishes,
> > spinsight
Hi, Hal:
At least in Canada, CiCi calling card is popular and cheap for
international calls and I cannot imagine it cannot be used by XP FAX. If you
don't mind too much, I would like to give your the detailed information of my
calling card and you may find what is the reason. That may be the quickest
method to solve this problem and won't waste your time.
Best regards,
Spinsight
> Hal
> > fax
> > recipents'
> > I
> > that
> > cards.
> > (Canada)
> > Thanks in advance!
> > Best wishes,
> > spinsight
So, you're saying the number is dialed by your modem both with and without
the calling card, the difference being that your modem does not detect the
destination answering when you use a calling card and DOES detect the
destination answering if you dial directly? If this is the case and the
only difference is the calling card service, this may be difficult to solve
as they may be the trouble source.
Hal
news😀70B7F9C-8157-41C5-82AE-A5E37771C885@microsoft.com...
> Hi, Hal:
> the
> Sincerely,
> Spinsight
>> out
>> proper
>> says
>> manually
>> Hal
>> > international
>> > fax
>> > recipents'
>> > addition,
>> > I
>> > fax
>> > that
>> > cards.
>> > (Canada)
>> > from
>> > wrong
>> > the
>> > problem?
>> > Thanks in advance!
>> > Best wishes,
>> > spinsight
Hi, Hal:
Thanks first for your help.
It is more likely problem lies in the calling card, as you suggested. I
inquired the calling card service to confirm this possibility, but they told
me that I could try it and they didn't guarantee the result. Probably, the
CiCi provides a ISP which is so different from that of my direct long
distance service.
Thank you again for your help and your time on my problem.
Best regards,
Spinsight
> Hal
> > Hi, Hal:
> > the
> > Sincerely,
> > Spinsight
> >> out
> >> proper
> >> says
> >> manually
> >> Hal
> >> > international
> >> > fax
> >> > recipents'
> >> > addition,
> >> > I
> >> > fax
> >> > that
> >> > cards.
> >> > (Canada)
> >> > from
> >> > wrong
> >> > the
> >> > problem?
> >> > Thanks in advance!
> >> > Best wishes,
> >> > spinsight
