Question Problem scanning with my AIO printer ?
ex_bubblehead
Champion
It's either the feed rollers slipping in the lid or the scanning head is hanging up on the rails under the glass. It all depends upon just exactly how you obtained that sample. Either way it requires disassembly and cleaning/lubrication. It can also be dirty glass not allowing the original to slide through without sticking. Do NOT use any type of ammoniated glass cleaners on copiers/scanners.
